Reporting and Exporiting individual data
Good Morning,
I am trying to find a way to report true positions data with additional report with PiWeb pdf report BUT only export true position without the additional data to table file(chr.txt file). 3033_2369f5b7babc7259d6c82a61778f61a5.jpg
I would like the Additional Data to report on the piweb PDF report so operators can see the X, Y, and Z locations so they make adjustments to the machine. The data in Blue.
I would like the _chr.txt file to only contain the Data in Green and remove the data in Red. I am using the txt file with another program to be able to pull data but the additional data of X Y Z locations and (M) are being pulled too which is throwing everything else off.
Is this possible or would I need to turn off additional data in piweb so I can export the true position properly.
Are you talking about piweb designer? Because I don't think I have used that. I have only used the template for standard protocol. Can that be modified?
In the drop down menus select;
Resources
...Characteristic Settings Editor
......Additional Printout
Set Additional Printout to "Off" for all the true psositions.
This will remove the extra data from the PiWeb report and leave it intact in the chr file.
Yes but the thing is, I want it to show on the PiWeb Report and I don't want it to show on the chr file.
Yeah I do. I have modified it a bit but the standard protocol template had a bunch of jumbled up lines I am not sure which one is to keep the additional data on the report but remove it when exporting to chr txt file. 3033_25ff1d33bbdc0aacfbda6a01f3fd8ae2.png
