[Ni...] Posted July 6, 2020 Share Posted July 6, 2020 Good Morning, I am trying to find a way to report true positions data with additional report with PiWeb pdf report BUT only export true position without the additional data to table file(chr.txt file). I would like the Additional Data to report on the piweb PDF report so operators can see the X, Y, and Z locations so they make adjustments to the machine. The data in Blue. I would like the _chr.txt file to only contain the Data in Green and remove the data in Red. I am using the txt file with another program to be able to pull data but the additional data of X Y Z locations and (M) are being pulled too which is throwing everything else off. Is this possible or would I need to turn off additional data in piweb so I can export the true position properly. Link to comment Share on other sites More sharing options...
[Sa...] Posted July 6, 2020 Share Posted July 6, 2020 You can select certain characteristics when selecting the data binding for the report. Link to comment Share on other sites More sharing options...
[Ni...] Posted July 6, 2020 Author Share Posted July 6, 2020 Please sign in to view this quote. Are you talking about piweb designer? Because I don't think I have used that. I have only used the template for standard protocol. Can that be modified? Link to comment Share on other sites More sharing options...
[Ri...] Posted July 6, 2020 Share Posted July 6, 2020 In the drop down menus select; Resources ...Characteristic Settings Editor ......Additional Printout Set Additional Printout to "Off" for all the true psositions. This will remove the extra data from the PiWeb report and leave it intact in the chr file. Link to comment Share on other sites More sharing options...
[Ni...] Posted July 7, 2020 Author Share Posted July 7, 2020 Please sign in to view this quote. Yes but the thing is, I want it to show on the PiWeb Report and I don't want it to show on the chr file. Link to comment Share on other sites More sharing options...
[Sa...] Posted July 8, 2020 Share Posted July 8, 2020 Please sign in to view this quote. Yes, all templates can be modified... do you have piweb designer? Link to comment Share on other sites More sharing options...
[Ni...] Posted July 9, 2020 Author Share Posted July 9, 2020 Please sign in to view this quote. Yeah I do. I have modified it a bit but the standard protocol template had a bunch of jumbled up lines I am not sure which one is to keep the additional data on the report but remove it when exporting to chr txt file. Link to comment Share on other sites More sharing options...
