[Le...] Posted July 7, 2020 Share Posted July 7, 2020 Hello, where can I change the default output directory for results? Link to comment Share on other sites More sharing options...
[Gr...] Posted July 7, 2020 Share Posted July 7, 2020 The settings you are looking to change are under environment. You can access it either from the pull down menu or under settings on opening screen. Once open choose paths and this is where you can make the changes. If you pick 'Fixed directory for actual values' enter the path you want measured points saved, if you've activated that feature, Calypso will automatically create a folder in that destination. Under 'Default Path for Results Files' enter where you want the reports saved i.e. Excel, .pdf, and .txt documents saved. Since we save to a network it will not automatically create any folders so create a file path ahead of time and enter it here. Link to comment Share on other sites More sharing options...
