Disc probes in stylus creator
Hello,
I've got a question about the stylus creator.
Is it possible to assemble a disc probe (zeiss no 626113-0700-050) on a XXT TL3 adapter plate in the creator because I can't find any of those.
Only sphere, cylinder, cone etc... is available.
Is there a database with more probes then the already available ones in the creator?
Thanks in advance,
Johan
https://qualityforum.zeiss.com/topic/15290-disc-probes-in-stylus-creator/
We use Discs fi10, fi5.5 and fi4.4 on our XXT TL3 Contura and after defining it and calibration every day it works fine.
But if it needs corrections you have to do it manually. First time you are doing it, it takes time, but after a while, when you get hold of it, it becomes familiar.
So yea, it's possible to use discs on XXT, but it is almost impossible to assemble it in Creator for Simulation.
There are some tricks, but the end result is not that great(for simulation).
