Comparison of 2 assembled multi material parts
Hi Everyone,
I need to compare two samples of multimaterial assembled parts. I have scanned the pars obtaining 2 volumes. Each volume through the poligonalization creats 2 different mesh (one for each material). What is the proper workflow to compare the samples? My first idea is to create a cad form actual data for one sample and then compare the other, but the presence of two different materials makes the process more difficult. Could you help me?
Thanks a lot
One solution could be to import the "second" volume as new stage data to the existing volume in the project.
Then each part will have a polygonization per stage.
You could then use a surface comparison between stages to compare the scans to each other.
