Duplicates of true positions in report
On a part I'm measuring, I use MMC for the true positions. For some reason, my report shows duplicates of the true positions without the MMC (shown in the picture). Why is that? How do I make the report show only the MMC true positions? In other words, I want to get rid of all the "position" lines that do not have "M".
P.S. I don't have any duplicates in my measurement plan but they are showing up in my report and I want to figure out why.
Report.rtf
Have you tried selecting only specific characteristics from the data binding? I have a similar issue, where I will have two or three submeasurements for characteristics. I changed my settings from "All characteristics and child characteristics" to "only selected characteristics" and singled out which ones I need. This works with a small amount of characteristics, but I wouldn't recommend it if you plan to have over 50 characteristics.
  • 2 weeks later...
As far as I can tell, the first line is the actual report. The line with the (M) is what the data would look like if it was normalized.
There is a way to turn off the lines with (M) because that is additional data, but I haven't found a way to turn off the true data and only leaving the additional data on.
I am still new so it might be hidden somewhere in there.
The setting of which I speak is within Piweb Designer. When selecting a data binding, you can pick out specific characteristics you wish to keep. Your screenshot does not appear to be in Piweb Designer... but if you have an idea of what I am talking about I would be more than happy to include screenshots to guide you along the process.
