Over-write / Append
I'm using this to send the report to two folders. It works fine, but
the file is being over-written each time. How can I make it append?
filePath = "T:\DMR\CMM Data\100518 Op-120_Rev_A\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt"
if fileExists(filePath) then // if it can't find the file then it will not error out.
if Part_Type == "Set-up"
copyFile(filePath,"T:\DMR\CMM Data\100518 Op-120_Rev_A_Set-up\theresults.txt")
else
endif
if Part_Type == "Production"
copyFile(filePath,"T:\DMR\CMM Data\100518 Op-120_Rev_A_Production\theresults.txt")
endif //inquireList
else
message("could not find file : " + filePath)
endif //fileExists
You need to parse the new file and add the content to the existing file.
You will need readListFile() and addToFile().
Here is a small example for you to play with:
	content=readListFile(filepath)
	for i = 1 to content.size
		addToFile("T:\DMR\CMM Data\100518 Op-120_Rev_A_Set-up\theresults.txt",getParameterNamed(content,i))
	next i
else.....
or
addToFile("T:\DMR\CMM Data\100518 Op-120_Rev_A_Set-up\theresults.txt",readListFile(filepath))
