PCM/Speed
I have this in my features presetting's;
setInspectionDrivingSpeed(30)
This a two part family PCM program. I've inserted this to protect the XXT from driving into the part (which is pointed and sharp). This could happen if the operator chooses the wrong part number to run. It work's fine, but from the time it leaves the previous feature, to the time it arrives at the slow one is too long. How can I make this speed incremental, or have it start to slow down closer to it arriving at the feature in question?
You're probably suffering from the same bug that sometimes happens when you lower the speed for a certain feature in the inspection plan editor: the CMM already slows down when it leaves the previous feature instead of when it arrives at the slow one. If that is the case, I fear you can do nothing about it (except file a bug report).
