[Ri...] Posted June 18, 2020 Share Posted June 18, 2020 Does anyone know how to, or if it isn't possible when it will be possible, get Calypso to send the additional data for things like Runout, Line Profile, and Perpendicularity (Plane to a Bore)? The only way that I can get Line Profile measurements is if I use the Curve Form characteristic. PiWeb Reporting Plus has tons of graphical options, but either I'm doing something wrong (which is possible) or they don't work for PiWeb SBS/Enterprise. If anyone has some knowledge to this, it would be greatly appreciated. Thank you. Link to comment Share on other sites More sharing options...
[28...] Posted June 19, 2020 Share Posted June 19, 2020 Hi Richard, How are you uploading your data to PiWeb? Using Calypso Interface? (yellow box that pops up where you configure UploadOptions.upl?) If you use Reporting Synchronization through Results to File instead of PiWeb Export: ON you will be able to upload the form plot for Line Profile. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 19, 2020 Author Share Posted June 19, 2020 Please sign in to view this quote. Hi Laura, Yeah, I've been using the PiWeb Upload tool. Let me play around with the Reporting Synchronization. How well does that handle customer header variables? As well as our PiWeb Upload tool has custom mapping depending on different variables. Link to comment Share on other sites More sharing options...
[28...] Posted June 22, 2020 Share Posted June 22, 2020 It works the same way as the Calypso Interface. You map the variables from Calypso to the appropriate attribute in PiWeb. The Reporting Synchronization has the same left column to right column approach as what you're used to. If you need help with it, let me know. Link to comment Share on other sites More sharing options...
