Profile headache
I have a profile for a slot feature in my casting drawing. What feature should I select for this?. I created a slot but calypso didn't take it as a feature for profile, I think a 3D feature required for profile. In my cad model two radius side have cones and flat side have planes. I have curve but lam that much familer with curve. Should I go for a 3D curve??
I'm guessing that you are measuring that in the XY work plane?
Slice through the model to create at least two 2d curves around the slot, and recall the points into a FFS for evaluation.
How can I change the nominal value of my profile, I get wrong nominal value in the piweb report..
My 2D curve co ordinate value related to base alignment in y axis 55 and x axis zero, when I created a slot its value is correct, but in curve it shows wrong, I don't know where I made the mistake..
Did you have this box checked (Re-calculate Nominal Geometry), when you recalled the points into the slot?
Try creating it again, this time with that box in-checked. That may be your problem, not 100% sure.
