Profile headache
I have a profile for a slot feature in my casting drawing. What feature should I select for this?. I created a slot but calypso didn't take it as a feature for profile, I think a 3D feature required for profile. In my cad model two radius side have cones and flat side have planes. I have curve but lam that much familer with curve. Should I go for a 3D curve??
IMG20200619164014.jpgFetching info...
I'm guessing that you are measuring that in the XY work plane?
Slice through the model to create at least two 2d curves around the slot, and recall the points into a FFS for evaluation.
How can I change the nominal value of my profile, I get wrong nominal value in the piweb report..
My 2D curve co ordinate value related to base alignment in y axis 55 and x axis zero, when I created a slot its value is correct, but in curve it shows wrong, I don't know where I made the mistake..
Did you have this box checked (Re-calculate Nominal Geometry), when you recalled the points into the slot?
Try creating it again, this time with that box in-checked. That may be your problem, not 100% sure.
