True Position Question
We have a plate that is 35" X 25 " x .75" the plate has a .05 bow/twist. Datum A is top. Datum B is long edge. Datum C is short edge. Position of holes in plate is between .028 and .056. We are getting position showing to be between .003 and .005.
Should the flatness of datum A throw off the true position or am I thinking about this wrong. The other inspectors and I are going " There is know way the holes can be this close with the Datum A not being flat"
https://qualityforum.zeiss.com/topic/15444-true-position-question/
Are the holes positioned to [A|B|C]?
If datum feature A has a lot of form error, your holes will probably not be very perpendicular to your derived primary datum plane, and thus throw the position out.
How are you evaluating the plane? Least squares/Outer tangential? How are you probing/scanning?
https://qualityforum.zeiss.com/topic/15444-true-position-question/#findComment-83478
