Pictures on the run Screen
If you save a picture and name it "icon.bmp" and put it in the program file of a program itll show up in the upper left corner of the launch window where the generic picture of the CMM is, but itll only be an inch square so thryre will be no definition.
If you have PCM you can put a run PCM file command in the presettings, but that won't pop up until you hit go.
And unless theres a file command i'm unaware of you'll need to run it thru a bat file, which isn't difficult but is an extra step.
You could also put a "Do you want to see a picture of how to do your job" pop up box with an if statement so when you hit go a box will pop up and only show the picture if you want it.
