[SH...] Posted June 17, 2020 Share Posted June 17, 2020 This is the first time lam running a loop program. In loop programming, program running second time we have to take the alignment manually again?? Calypso asks me to measure the alignment. I also got some timing window, I can't understand what does it mean??IMG20200617184911.jpg Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/ Share on other sites More sharing options...
[Me...] Posted June 17, 2020 Share Posted June 17, 2020 Are you looping the base alignment, secondary alignment or select features? Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83750 Share on other sites More sharing options...
[Ri...] Posted June 17, 2020 Share Posted June 17, 2020 If you place a loop on the program, if the Run screen was set to a manual alignment, it will ask you to do it again. Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83752 Share on other sites More sharing options...
[SH...] Posted June 17, 2020 Author Share Posted June 17, 2020 Please sign in to view this quote. Entire program. Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83754 Share on other sites More sharing options...
[SH...] Posted June 17, 2020 Author Share Posted June 17, 2020 Please sign in to view this quote. Ok, got it. So l have to run on current alignment. Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83756 Share on other sites More sharing options...
[Ke...] Posted June 17, 2020 Share Posted June 17, 2020 [/quote] Ok, got it. So l have to run on current alignment. [/quote] If you have a Start Alignment (it can be the same as your Base Alignment), then you can run Manual Alignment, and only need to probe once (don't forget to click the Start Alignment radio button, above the alignment selection) Or You can go to the screen where you set up your Base Alignment, and click the "Execute manual Run Now" Icon... probe your Base Alignment... then run program with the proper Base Alignment selection Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83758 Share on other sites More sharing options...
[Ri...] Posted June 17, 2020 Share Posted June 17, 2020 Please sign in to view this quote. No. Don't run from Current Alignment. I would execute a Manual Alignment from the Base Alignment window. Then in your CNC Run screen run from the program name alignment. Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83760 Share on other sites More sharing options...
[SH...] Posted June 17, 2020 Author Share Posted June 17, 2020 Thanks for all the reply, I will use execute manual run now. Link to comment https://qualityforum.zeiss.com/topic/15470-loop-program-doubt/#findComment-83762 Share on other sites More sharing options...
