Default Report
Has anyone figured out to disable default reports from popping up? It is the most annoying thing ever.
I tried searching for this, but this site's search function always ignored "report" and I couldn't find anything.
I believe you have to go to Multiple Printout --> select Default Printout from the "Printout Features" drop down.... select the Default Printout, and turn the green Checkmark into a red X.... on every program (or set this up as a dummy Measurement Plan, and use it to begin every program.
You can also save your multiple report definition and load it when starting or updating programs.
I tried all that, but whenever I open a feature, the default report still pops up.
I disabled everything other than the piweb report.
And it looks like this?
What version are you on? I felt like the initial release of 2018 had this problem where you couldn't disable the Default Printout no matter what, but I believe later Service Packs addressed this.
I'm 2019 as well. Does it make a difference if I actually DELETE "default" from the picture as opposed to applying the red "x" to it?
The default report has to be included in your multiple printout definition in order to get rid of it. If you have it listed, and you've unchecked the display icon for it, and it still appears, then Calypso 2019 must have some fun new bug.
