[De...] Posted February 12, 2020 Share Posted February 12, 2020 Looking to see if anyone can help to get more than one set of results in one PiWeb report. For example, on a 30 piece capability study I don't want to have to spit out 30 different PDF's, one for each part run. I know this can be done through Excel and likely Custom Report as well. But I really need to keep this in the same format as our previous reports which are all done in PiWeb. There has to be a way?! Thoughts? 💡 Thank you. Link to comment Share on other sites More sharing options...
[Ün...] Posted February 13, 2020 Share Posted February 13, 2020 you can use the attached template where only the last 20 pieces will appear. Maybe you can increase the number by lowering the fonts, but this will take time. Link to comment Share on other sites More sharing options...
[De...] Posted February 13, 2020 Author Share Posted February 13, 2020 Thank you, I will give it a try! 😃 Link to comment Share on other sites More sharing options...
[Te...] Posted February 17, 2020 Share Posted February 17, 2020 Have you tried the process report that should give you the last 30 runs or at least the ability to get the last 30 runs. Link to comment Share on other sites More sharing options...
[ge...] Posted February 18, 2020 Share Posted February 18, 2020 I use this just select the dimensions you want to use and can generate up to 100 data or more CPK.zipFetching info... Link to comment Share on other sites More sharing options...
[Sa...] Posted June 1, 2020 Share Posted June 1, 2020 I managed to expand the report out to have a width of 500 Inches. This made it easy to run through 300+ parts in one page. Not sure if this is still a relevant question however. Link to comment Share on other sites More sharing options...
[Ia...] Posted June 11, 2020 Share Posted June 11, 2020 Please sign in to view this quote. Thanks. I will give this a try. Link to comment Share on other sites More sharing options...
