[Ia...] Posted June 8, 2020 Share Posted June 8, 2020 Is there a way to filter out specific points on a curve? Like somewhere to input a range of points to disregard? Link to comment https://qualityforum.zeiss.com/topic/15558-curve-masking/ Share on other sites More sharing options...
[Me...] Posted June 8, 2020 Share Posted June 8, 2020 Open the Evaluation tab of the curve. Go to Limit Evaluation. If you click on Nominal vector direction/Parameters a dialogue opens where you can choose the points you want to use/not use in the evaluation. Or you can select them by start and endpoint below that. Link to comment https://qualityforum.zeiss.com/topic/15558-curve-masking/#findComment-84346 Share on other sites More sharing options...
