[Da...] Posted June 5, 2020 Share Posted June 5, 2020 Hello to all people 😃 , it's my first post here. I have to measure a spiral of a special thread, I have a problem with scanning. In strategy, due to type of scan I have to do, I have programmed a single spiral (240 degrees of circumference 2/3) and the number of points setted is 270, but after scanning, calypso collects more than 15000 points. Does anyone have had a similar problem? How did you resolved? Best regards to all. Davide CALYPSO 6.8.1201 PRISMO CALYPSO 6.6.28 O-INSPECT Link to comment Share on other sites More sharing options...
[Ca...] Posted June 5, 2020 Share Posted June 5, 2020 I've seen this too. I don't have an explanation for it. As long as it doesn't (greatly) increase cycle time, I leave it alone. Link to comment Share on other sites More sharing options...
[Kl...] Posted June 5, 2020 Share Posted June 5, 2020 Hello Davide, please make a screen Dump which element and strategy you used. Link to comment Share on other sites More sharing options...
[Me...] Posted June 5, 2020 Share Posted June 5, 2020 Did you create spiral as a free form surface? If yes in strategy you will see a point set with 270. But the number of the points that will taken is seted inside point set. Maybe this will be the problem. Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Author Share Posted June 5, 2020 This is what happens, helix is scanned with rotary table. Waiting for yours opinions. Italian support is analysing that problem to understand what's the matter. have a nice day.ERRORE_CALYPSO_PUNTI.png Link to comment Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Share Posted June 5, 2020 If you use the Single point probe it do you get the same thing? Check the Single point box Link to comment Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Share Posted June 5, 2020 the other thought is it a calculation error change the number of points to 3 Then see how many point it probes Link to comment Share on other sites More sharing options...
[Ma...] Posted June 8, 2020 Share Posted June 8, 2020 If you are running this on the O-inspect CALYPSO 6.6.28 have you installed the latest patch for this? The latest release was on 5/5/2020 for ZEISS_CALYPSO_2018_Patch_v6.6.2808.msp. Link to comment Share on other sites More sharing options...
