XTR Simulation - Column in the Stylus
I have an issue with simulation on XTR probehead. The stylus system apears inside the column.
It was fine for a long time and only started recently. I have tried creating a new machine, but the same thing happens.
I know that on RDS you have to change some values in Stylus System tab in CMM configuration, but on XTR I did not have to do that before.
Any ideas?
Thanks
Yes, I did,
And the same thing happens to the masterprobe.
It is weird because it was working right for 2 years and suddenly stopped.
I'm not sure if I was installing any service packs in the meantime.
