[Wo...] Posted June 5, 2020 Share Posted June 5, 2020 I have an issue with simulation on XTR probehead. The stylus system apears inside the column. It was fine for a long time and only started recently. I have tried creating a new machine, but the same thing happens. I know that on RDS you have to change some values in Stylus System tab in CMM configuration, but on XTR I did not have to do that before. Any ideas? Thanks Link to comment Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Share Posted June 5, 2020 It looks right? Did you create your master probe first? Link to comment Share on other sites More sharing options...
[Wo...] Posted June 5, 2020 Author Share Posted June 5, 2020 Yes, I did, And the same thing happens to the masterprobe. It is weird because it was working right for 2 years and suddenly stopped. I'm not sure if I was installing any service packs in the meantime. Link to comment Share on other sites More sharing options...
[ke...] Posted June 5, 2020 Share Posted June 5, 2020 Ours had a bug in the software, to be fixed on the next update. viewtopic.php?f=13&t=3053&p=19598&hilit=jennifer#p19598 Link to comment Share on other sites More sharing options...
