[Da...] Posted June 4, 2020 Share Posted June 4, 2020 Is there a way to assign a PCM variable to a characteristic name? For example, assume I am reporting a X-Location for a circle. I would like use a variable to change the default name to "Item 1". Is this possible? Link to comment Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 There is something in the release info of Calypso 2018: viewtopic.php?f=13&t=1110 no idea how to use it Link to comment Share on other sites More sharing options...
[Is...] Posted June 5, 2020 Share Posted June 5, 2020 As an alternative you can translate your Piweb output with the command TR() Link to comment Share on other sites More sharing options...
