[Ch...] Posted June 4, 2020 Share Posted June 4, 2020 Does anyone know what triggers this error? It only happens with PiWeb reports. Switch this to a custom report and it outputs just fine. I don't get this error very often, but it bugs me that I can't figure out what is causing it. Link to comment https://qualityforum.zeiss.com/topic/15592-endpoint-error/ Share on other sites More sharing options...
[Ma...] Posted June 4, 2020 Share Posted June 4, 2020 Are you seeing this happen only when using specific measurement plans? I'm not sure what the error I had was exactly, but it looked similar to what you got. The problem I had was I had 2 PDF results with the same name trying to save to a folder. Link to comment https://qualityforum.zeiss.com/topic/15592-endpoint-error/#findComment-84552 Share on other sites More sharing options...
[Ch...] Posted June 4, 2020 Author Share Posted June 4, 2020 This is program specific problem. It is also a PiWeb specific problem. I switch it to custom report with the same name and it outputs fine. Link to comment https://qualityforum.zeiss.com/topic/15592-endpoint-error/#findComment-84554 Share on other sites More sharing options...
[Ma...] Posted June 4, 2020 Share Posted June 4, 2020 Please sign in to view this quote. Yeah mine was with PiWeb as well. Do you have both custom report and PiWeb selected (checked) in your output directories? That was my problem. The "name of output file variable" needed to be unchecked for the custom report if I was using PiWeb. It was a while ago, but I think that is what solved my problem. Could also be 2 different errors, there's also that. 🙂 Link to comment https://qualityforum.zeiss.com/topic/15592-endpoint-error/#findComment-84556 Share on other sites More sharing options...
[Ch...] Posted June 4, 2020 Author Share Posted June 4, 2020 Unfortunately, that didn't work, but I think we are onto something. I played around with the 'name of output file variable' and that didn't do it. I have a work around for now but I'm gonna figure this out. Link to comment https://qualityforum.zeiss.com/topic/15592-endpoint-error/#findComment-84558 Share on other sites More sharing options...
