mini plan
  • 1 month later...
Yes you can.
"C:\Users\XYZ\Desktop\mainfolder\"+getRecordHead("measRun")+"\"+getRecordHead("planid")+getRecordHead("dateshort")+getRecordHead("time")+".pdf"
You just need to add ("\") after selecting measrun from report header fields.
So I'm terrible at this, and I'm just doing this to get better. I'd like to make a file path that goes into the results folder, then into a folder of the "planid", and then in that folder of the miniplan/all characteristics. I thought this would work, but it isn't.
"C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\"+getRecordHead("planid")+"\"+getRecordHead("measRun")+"\"+getRecordHead("planid")+getRecordHead("dateshort")+"-"getRecordHead("time")+".pdf"
Can anyone point me in the right direction?
I guess you miss one "+" before time stamp. Can you try this?
"C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\"+getRecordHead("planid")+"\"+getRecordHead("measRun")+"\"+getRecordHead("planid")+getRecordHead("dateshort")+"-"+getRecordHead("time")+".pdf"
Did the same thing as before. It Names the part the planid, but with the increment part number after? Just goes right in the results folder.
