what is the lowest version of Calypso that can be used with Windows 10?
I have 4.2 4.8 and 5.4 all running on windows 10
6.0 and up work with no problems during the install.
It will require some additional steps to make all the other older versions then 6.0 work
I had to install 6.0 then clean the program completely off with Ccleaner but leaving the C++ and SQL server installations done by Calypso on the computer to the data of the version of software.
Then do the install of calypso software I wanted to run.
You can run all versions on the same computer from 6.0 and up but I have not got it to work on anything lower without Partitioning the Hard Dive.
