[Do...] Posted April 6, 2020 Share Posted April 6, 2020 Hello Fellows, I hope that my question was to be clear. Usually my diameter over balls values (Gear-Pro) doesnt match micrometer values.(diference between 0.02mm always bigger) I would like to know, if we have any parameter for adjust inside Gear-Pro program or step by step for check something wrong thanks for help Link to comment Share on other sites More sharing options...
[Ri...] Posted April 7, 2020 Share Posted April 7, 2020 The only way that would get you "close" would be to use the same size diameter stylus as your ball/pin. Micrometers are not very consistent due to operator variances. I'm a big fan of the double-flank measurement inside of GearPro. I'm not a huge fan of the single-flank measurement as all of the calculations are theoretical, and as the parts deviate more the more variance in the measurement grows. Link to comment Share on other sites More sharing options...
[Wo...] Posted June 1, 2020 Share Posted June 1, 2020 Please read my answer in MdK Measurement Regards Wolfgang 🙂 Link to comment Share on other sites More sharing options...
