Visual alert
Our military division has requested I look into seeing if there is a way for the operators while away from the O-inspect to be alerted by way of a light when the program stops, or faults out. I'm sure that with PCM something like this might be possible, but we currently don't have PCM on this machine. Are there alternative methods that are offered by Zeiss, or even something I could add myself?
https://qualityforum.zeiss.com/topic/15684-visual-alert/
5.500$ for a fu*#&ng light? 😱
Thats the most absurd pricing from Ziess Iv'e heard so faar.
How about a raspberry pi zero, a relay, what ever light souce you have around. Thats like 15$.
If you need help with a schematic and code just let me know and I'll gladly do it for you...
....5.5k.... 😱
https://qualityforum.zeiss.com/topic/15684-visual-alert/#findComment-85358
The reason for that crazy price is that even though there in the software it is possible to enable light signal.It need its own circuit board which is not part of standard configuration and there isn't even space for the circuit board either.
I don't know much about circuit boards, but I guess it should be pretty easy to find that kind of space.
Just tried a converter and it is not 5,5k but 4,7k
Have you made a similar light signal before. Our production would really appreciate it. At least 10 times a day they go to our CMM just to find out it is not available.
https://qualityforum.zeiss.com/topic/15684-visual-alert/#findComment-85362
