How would you capture this datum?
It applies to all profiles and all holes along the entirety of the part, which are on the radius, and both flats. A is primary datum in all control frames.
I guess this brings up a different question. Using the can may must rule, if it CAN and may constrain them, it has to right? Or would basic dimensions override that?
I'm Guessing Note 4 is the defining the Datum?
I would use a profile scan make it best fit from the two planes with Rotation and translation.
Then use that Best fit alignment to check the other features.
I will try it tomorrow when I have time.
Send Screenshots.
Thanks
Dan
