Torus Datum?
I have a datum surface that is a torus, any ideas on how to get creative here?
The very end of the part (end of threads). I'm thing I might have to use a datum
feature simulator?
How is the torus being used as a datum? (using the central diameter, or the outer surface?)
I use torus' all the time, to locate/control measurements, but they are precision ground, and I typically have 80degrees of curvature available.
...That's a sticky wicket, even with a full feature...
If you're not measuring many parts (I deal with a lot of prototypes & benchmarking): Possibly a plane with a few tight circle paths, and use Outer Tangential.
But if you are running for production, DFS is probably the way to go.
