[Za...] Posted May 19, 2020 Share Posted May 19, 2020 What's the best way to get the reference bolt circle diameter in this print? Unfortunately, this is something that we have to give a measurement for, and I can't get the nominals to pull in correctly from the CAD. I haven't had any luck trying to recall the features into a circle as of yet. It looks correct on the screen, but I'm missing something because the nominal is coming in at 1.738ish and the print is calling for 1.728. Can anybody point me in the right direction? Thanks, Zach Link to comment Share on other sites More sharing options...
[Me...] Posted May 19, 2020 Share Posted May 19, 2020 Do a center to center straight line distance between the 2 holes. It doesn't matter what the bolt circle measures because the X/Y dimensions of the holes control the location and BC size. As long as those are in tolerance you're good to go. Link to comment Share on other sites More sharing options...
[Jo...] Posted May 19, 2020 Share Posted May 19, 2020 If you have a model, and used Polar caliper measurement, that nominal bolt circle is correct. Look at the nominals in X, Y for each hole. Maybe they rounded off somewhere. Link to comment Share on other sites More sharing options...
[Da...] Posted May 20, 2020 Share Posted May 20, 2020 Could you show us the actual X & Y coordinates of the two holes ? Link to comment Share on other sites More sharing options...
[Ow...] Posted May 20, 2020 Share Posted May 20, 2020 Nominal coordinates do equal the bolt circle diameter. Are you using the corner edge for alignment or the hole in the middle? Link to comment Share on other sites More sharing options...
[Za...] Posted May 20, 2020 Author Share Posted May 20, 2020 Please sign in to view this quote. Ahhh this makes sense, I'm aligned to the corner edges. The simple distance was in tolerance, but I'll mess with this later when I get some time. I bet it will come right in once I'm aligned to the middle bore. Link to comment Share on other sites More sharing options...
