[Ri...] Posted May 19, 2020 Share Posted May 19, 2020 Why not just do an unknown curve? I think you will be more successful doing it that way. Link to comment Share on other sites More sharing options...
[Ch...] Posted May 19, 2020 Share Posted May 19, 2020 I think Richard is right about the unknown contour. Link to comment Share on other sites More sharing options...
[Ke...] Posted May 19, 2020 Share Posted May 19, 2020 Please sign in to view this quote. Probably because I have only worked with CAD models, for the last 10 years, and I pretty much forgot about it 🤣 I used unknown curve, and it worked like a charm (after a little refresher) Thanks! Link to comment Share on other sites More sharing options...
[Ri...] Posted May 19, 2020 Share Posted May 19, 2020 Please sign in to view this quote. Awesome. I have used Circle in contour best fit a lot, coming from a gear background. It is a very powerful tool. Just like Curve. I have always said that Curve is the single most powerful tool in Calypso. Link to comment Share on other sites More sharing options...
[Is...] Posted May 20, 2020 Share Posted May 20, 2020 Please sign in to view this quote. Circle in contour best has the potential to be a powerful tool, however is very unstable, sometimes is not able to provide a result and the graphic is not accurate enough from my point of view. The good thing is that with enough effort you can develop a better method using PCM and curve. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 20, 2020 Share Posted May 20, 2020 Please sign in to view this quote. A lot of the problems that I have encountered is due to "noise" in the filter. A heavy filter/outlier elimination is needed if the part is rough. Link to comment Share on other sites More sharing options...
