Recall Curves
Probably because I have only worked with CAD models, for the last 10 years, and I pretty much forgot about it 🤣
I used unknown curve, and it worked like a charm (after a little refresher)
Thanks!
Awesome. I have used Circle in contour best fit a lot, coming from a gear background. It is a very powerful tool. Just like Curve. I have always said that Curve is the single most powerful tool in Calypso.
Circle in contour best has the potential to be a powerful tool, however is very unstable, sometimes is not able to provide a result and the graphic is not accurate enough from my point of view.
The good thing is that with enough effort you can develop a better method using PCM and curve.
A lot of the problems that I have encountered is due to "noise" in the filter. A heavy filter/outlier elimination is needed if the part is rough.
