[To...] Posted May 15, 2020 Share Posted May 15, 2020 Hello I am trying to make edit a bit in the Pi-Web reports. I would like to report the deviation from tolerance center instead of deviation from nominal value? Does anybody have an idea of how to do this? Link to comment Share on other sites More sharing options...
[To...] Posted May 15, 2020 Author Share Posted May 15, 2020 I found out by myself But this will give me another "problem". It is reporting that center of roundness is 0.05 and not 0.Is there any workarounds on this issue? Link to comment Share on other sites More sharing options...
[Ke...] Posted May 15, 2020 Share Posted May 15, 2020 Using original settings, would it help to set the tolerance to Min/Max Dimension, instead of using +/- tolerance? Link to comment Share on other sites More sharing options...
[3c...] Posted May 15, 2020 Share Posted May 15, 2020 Roundness will never be negative, so, that would be the middle of the tolerance band. Link to comment Share on other sites More sharing options...
[Ke...] Posted May 15, 2020 Share Posted May 15, 2020 Please sign in to view this quote. 🤣 Sorry, I just meant for the size dimension. Is this a special request from the "customer" Link to comment Share on other sites More sharing options...
[3c...] Posted May 15, 2020 Share Posted May 15, 2020 Please sign in to view this quote. Sorry, I should have specified that I was replying to the original poster. They were saying that they had a roundness tol of 0.10 and the MiddleofTolerance variable responded with 0.05. I suspect they were expecting it to be 0, not understanding that roundness would never be negative. 🙂 Link to comment Share on other sites More sharing options...
[To...] Posted May 17, 2020 Author Share Posted May 17, 2020 Please sign in to view this quote. I am aware of this that is why I wrote "problem. it is the center of the tolerance bar, yes. But is it really in the center of the tolerance? but that is another discussion. I would just like to know if I can make some kind of setting which allows my to differ between normal tolerances and roundness or position. Link to comment Share on other sites More sharing options...
