Keep your Air line Free of Oil and Water
So I have spent the last 4 days working on a Mitutoyo Bright CMM trying to get it back in to manufacturer spec. Just a heads up if you let oil get in to the air-bearing it really screws up your accuracy. Don't let it happen clean your filters. Get an air dryer if you need one. Do what every it takes. The first time I saw what oil can do was on a new Mitutoyo Crysta Apex with a design flaw. The flaw allowed oil to get in to the balance cylinder. Each year the calibration was off 8 to 12 microns Mitutoyo would clean it then back to 2.5 until the next calibration. But if you get oil in the air-bearings it takes a year or so to get all of the oil out of your machine.
So clean your CMM check the air-filters
Those DuraMax owners "You Ain't Got No Worries".
Below are the repeatability test for the Mitutoyo Bright.
Look at the Y axis up to 15 microns dev. All because of oil, just a little oil.
Capture1.PNGFetching info... Capture.PNGFetching info...
