[Cl...] Posted May 12, 2020 Share Posted May 12, 2020 I have a variable (a part number) in my .para file. I put this in a Text Element, so the part number shows up on the report, It worked last week, now it doesn't show up on the report, but it shows up in the Text Element. Link to comment Share on other sites More sharing options...
[De...] Posted May 12, 2020 Share Posted May 12, 2020 Old style report? Figured I would at least ask since TextElement does not work on piWeb. Link to comment Share on other sites More sharing options...
[Cl...] Posted May 12, 2020 Author Share Posted May 12, 2020 For production we use the compact printout. The program uses PCM for the different sizes, so rather than rely on the operator to enter the part number in the Report Header Data - Incremental Part Number area, I have it as a variable in the .PARA files for each part number. I call it up in a text element, then it automatically shows up on the report. It was working fine last week. Now, not there? It's got to be something very simple I'm overlooking? Link to comment Share on other sites More sharing options...
[De...] Posted May 12, 2020 Share Posted May 12, 2020 Try a message(variable) in the postsettings of the plan .. see if the variable is still set at the end of the run. If it is, then I don't know. Maybe show your code? Link to comment Share on other sites More sharing options...
[Cl...] Posted May 12, 2020 Author Share Posted May 12, 2020 Text Element wouldn't accept anything numeric, so I had tp change it to; text(Part_Number). When I made the change, I must have forgot to hit save Link to comment Share on other sites More sharing options...
