[He...] Posted May 5, 2020 Share Posted May 5, 2020 A better description regarding the point modes than what the Calypso help provides. Calypso___Space_point_modes.pdfFetching info... Link to comment Share on other sites More sharing options...
[To...] Posted May 6, 2020 Share Posted May 6, 2020 Please sign in to view this quote. Great post, Henrik. For us who are rather new to Calypso this explain a lot. Link to comment Share on other sites More sharing options...
[SH...] Posted May 6, 2020 Share Posted May 6, 2020 Please sign in to view this quote. The cad face point Explanation is little bit confusing, so we can't check true position using cad face point, So what point should use for true position? plane point or space point. Link to comment Share on other sites More sharing options...
[He...] Posted May 6, 2020 Share Posted May 6, 2020 Please sign in to view this quote. If you are looking to evaluate profile with single points then space point is the best option. Link to comment Share on other sites More sharing options...
[SH...] Posted May 6, 2020 Share Posted May 6, 2020 Please sign in to view this quote. Yes, Link to comment Share on other sites More sharing options...
[An...] Posted May 7, 2020 Share Posted May 7, 2020 So when it comes to Profile: 6.) Plane 7.) Space 8.) Net 9.) Cad Face yield the same result? Link to comment Share on other sites More sharing options...
[SH...] Posted May 7, 2020 Share Posted May 7, 2020 Please sign in to view this quote. This is applicable only for individual point measurement?? suppose we measuring 3D curve without points,Does this different type of point matters?? Link to comment Share on other sites More sharing options...
[SH...] Posted May 7, 2020 Share Posted May 7, 2020 Please sign in to view this quote. Separate licence required for the Blade Pro?? Link to comment Share on other sites More sharing options...
[Er...] Posted May 7, 2020 Share Posted May 7, 2020 Yes. Link to comment Share on other sites More sharing options...
[An...] Posted May 7, 2020 Share Posted May 7, 2020 The perpendicular from the cross to the nominal surface is the result of half Profile. See attached. Contribution_07_05_2020.pdfFetching info... Link to comment Share on other sites More sharing options...
[Da...] Posted May 11, 2020 Share Posted May 11, 2020 Please sign in to view this quote. Eric remember you are Swedish no (Rolls Royce in Sweden) And Trent are the High Bypass engines. Link to comment Share on other sites More sharing options...
[Er...] Posted May 12, 2020 Share Posted May 12, 2020 Okey... You really know it all dont you.... https://press.siemens.com/global/en/pre ... enter-long Link to comment Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Author Share Posted May 12, 2020 I do. I worked for Rolls Royce, They don't use High Bypass engines for generating power. And the Trent is a High Bypass engine. Just saying. Rolls-Royce Trent Engine family DescriptionThe Rolls-Royce Trent is a family of high-bypass turbofans produced by Rolls-Royce. It continues the three spool architecture of the RB211 with a maximum thrust ranging from 61,900 to 97,000 lbf. Launched as the RB-211-524L in June 1988, the prototype first ran in August 1990. Wikipedia First run: August 1990 Developed into: Rolls-Royce MT30 Manufacturer: Rolls-Royce Holdings Developed from: Rolls-Royce RB211 National origin: United Kingdom Awards: MacRobert Award Link to comment Share on other sites More sharing options...
[Cl...] Posted May 12, 2020 Share Posted May 12, 2020 For which particular aircraft are these engines used? I worked on FB-111's at RAF Lakenheath, UK. Link to comment Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Author Share Posted May 12, 2020 Airbus A330 Airbus A340-500 Airbus A340-600 Airbus A350 Airbus A380 Boeing 777 Boeing 787 Link to comment Share on other sites More sharing options...
[Er...] Posted May 12, 2020 Share Posted May 12, 2020 Aha, so I guess the industrial trent 60 doesnt exist then? 🤣 As someone wise once said, you'll never stop learning new stuff if you put your head out of your bubble. Link to comment Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Author Share Posted May 12, 2020 https://www.ge.com/reports/video-ge-sta ... et-engine/ This is the largest Jet Engine GE 9X https://www.youtube.com/watch?v=fE0DcD2Bxac https://www.youtube.com/watch?v=XEiWwRyq_9E https://www.youtube.com/watch?v=Y9_E2cj5eTE Link to comment Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Author Share Posted May 12, 2020 You didn't list the Trent 60 marine engine you listed the Trent RB211 Link to comment Share on other sites More sharing options...
[Er...] Posted May 12, 2020 Share Posted May 12, 2020 No I didnt, I said rb211 and trent. Exactly like that. I also made it pretty clear that they will never fly. Google rb211 industrial and stop jumping to conclusion. I think its time to you realize thay you guys sort of make your self look like fools. What is your problem? Link to comment Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Author Share Posted May 12, 2020 You did there are no 1000mm blades on a Trent Industrial engines The SGT-A65 or MT30 engines. But good luck with your store. Link to comment Share on other sites More sharing options...
[Er...] Posted May 12, 2020 Share Posted May 12, 2020 No, I really didn't... Feel free to check your self. And I said our blades range from... I didnt say either rb or trent has those blades. We make more engines then those two. Sure you are at the right form? You know this isnt mcdonaldsfanclub.com? Link to comment Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Author Share Posted May 12, 2020 OK 😕 Link to comment Share on other sites More sharing options...
[To...] Posted May 12, 2020 Share Posted May 12, 2020 Ever since March 5th, this forum has really gone down hill. It's almost as bad as Facebook. Link to comment Share on other sites More sharing options...
[He...] Posted May 12, 2020 Share Posted May 12, 2020 Please sign in to view this quote. I totally agree. It is really a shame. Especially if we loose new and old posting members because of it. Please sign in to view this quote. Nobody else likes it. So please stop doing it. Link to comment Share on other sites More sharing options...
[Er...] Posted May 12, 2020 Share Posted May 12, 2020 This is a shame. I used to come to the forum to look for help and understanding. Now we get off the topic opinions from egotistical people that doesn't matter at all. Please for the sake of the forum and the users that need help, Stop! Keep the subjects on topic, related to question posted. Thank you. Link to comment Share on other sites More sharing options...
