How to export CMM data into inspection Xpert?
I am trying to import data into InspectionXpert. I cant figure out the right format to do so. It mentioned using the excel reportINI.xls template. When I go to export using reportINI.xls in calypso it shows up blank and grayed out. Anyone know how to fix this issue ?
I would report using Characteristic.xlt.
reportINI.xls is, from what I can tell, an internal file used to create reports, not a template per se.
Let me know if that doesn't work - I use the excel export pretty extensively, and can probably give you a hand.
