[Me...] Posted May 7, 2020 Share Posted May 7, 2020 Agreed, Mark. I'm just trying to guide him in the right direction. "Can" it actually constrain the spatial properly? Probably not. But I wanted to start at the beginning and give him the basics before I tell him to ignore the print. 🤣 Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7, 2020 Share Posted May 7, 2020 What in the world is Datum A though? Link to comment Share on other sites More sharing options...
[Za...] Posted May 7, 2020 Author Share Posted May 7, 2020 Please sign in to view this quote. I'm sorry, it's not the undercut ID, but the .500" ID going through the center. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7, 2020 Share Posted May 7, 2020 OK. For your alignment, use Datum A as the Spatial Rotation in the Y axis, and as the X & Z Origin. Your Y Origin can be that -Y Plane that you have listed as being used for your Z Origin. For your Planar Rotation you need something better, it can be a couple of things either that plane on the top of the part (if it is nice and machined), or you can use the hole to to the top right that you are evaluating its distances for. Now when you use the hole as your Planar you will see that it rotates the axis to be in line with it, if you want it to match your drawing, do this. While inside of the alignment, go to Special - click on Rotate by distances - I'm assuming the Spatial is the +Y, so select that on the Rotate around - and then the distances are the nominals of the hole, so in this case I have 0.89 for the Z, and 0.66 for the X for an angle of 36.5596. If your axis isn't lined up like your drawing, then you may just have to swap the numbers around and make one or both negative. I hope this helps. Link to comment Share on other sites More sharing options...
[Za...] Posted May 9, 2020 Author Share Posted May 9, 2020 Please sign in to view this quote. Alright, I think I have it setup correctly and the holes seem to be in tolerance. Is there a way to pull this data from this best fit and report it separately? Pic4.pngFetching info... Link to comment Share on other sites More sharing options...
[Za...] Posted May 11, 2020 Author Share Posted May 11, 2020 Is there anyway to pull this data from the 2d best fit into a Result Element? I want to list the X and Z (Y) locations separately according to the balloon print I'm following. Is this possible? Link to comment Share on other sites More sharing options...
[Za...] Posted May 11, 2020 Author Share Posted May 11, 2020 So I thought I had this figured out so I could pull the X and Z locations from the best fit and report it into a result element, but it's not reporting the correct x and z values. Does anybody know of a way to report the diameters from the best fit that are highlighted here? Pic3.pngFetching info... Link to comment Share on other sites More sharing options...
