PCM & Speed
Figured it out. Feature - Presetting's.
I've got a PCM program for a part family. The only thing than changes is the OAL. The part is very sharp at one end.
If the operator chooses the wrong part number to run, the sharp tip will crash into the XXT adapter plate, puncturing it.
This way, if it crashes at 30mm/sec, no damage will occur. Unless someone has a better idea?
