[Cl...] Posted April 28, 2020 Share Posted April 28, 2020 I created two stylus qualification programs for each of our three Conturas. One for Geometry re-qual and one for passive. I've added characteristics (Result elements) with PCM that outputs the stylus sigma value. I want to add to that the stylus radius and the XYZ values. Is this possible? Link to comment Share on other sites More sharing options...
[Ia...] Posted April 28, 2020 Share Posted April 28, 2020 Try these out. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 28, 2020 Share Posted April 28, 2020 Ian is correct. The .probeVector.x .probeVector.y .probeVector.z commands are what you are looking for. Though the Vector portion throws me off. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 28, 2020 Author Share Posted April 28, 2020 Can Insert this code into the result element that I already use? Link to comment Share on other sites More sharing options...
[Ri...] Posted April 28, 2020 Share Posted April 28, 2020 You should be able to. Link to comment Share on other sites More sharing options...
[Jo...] Posted April 29, 2020 Share Posted April 29, 2020 Why not use default report to save your calibration data? Or if you have updated 6.8,you could use "Stylus data". Link to comment Share on other sites More sharing options...
[Cl...] Posted April 29, 2020 Author Share Posted April 29, 2020 Thanks for all the help guys. I went with the .radius & .probeVector.X, Y&Z in result elements. If I wanted to apply a tolerance to the radius value, what would it be? Link to comment Share on other sites More sharing options...
[Cl...] Posted May 11, 2020 Author Share Posted May 11, 2020 Now that I've got this incorporated into my stylus qualification programs, what tolerance would I apply to these XYZ vectors? Link to comment Share on other sites More sharing options...
