Programing languge for Calypso
this might be a little bit out there, but here we go:
I am trying to edit "inspection" file in Notepad++, does anyone know what language to choose to have the proper formatting?
what I am trying to do, is to change few standard warning messages,
i.e. if a variable in PCM is not defined, instead of standard message 'Parameter: M_Ang is not defined.' edit to ' M_Cone needs to be measured before creating 2D_Line_M"
or even create some case scenario action instead of error state
to give program editors more details to work with or some direction.
this is a big template that I am creating and less experienced programmers need to edit it.
#Dictionary
#apexAngle ' ->' 'rad(M_Ang * 2)')
#diameter ' ->' 'M'))
#parameters: ''
#warningMessage: 'Parameter: M_Ang is not defined.')
The inspection file and inspset file doesnt contain any language at all. Its Zeiss own formatting. And just information storage.
But ++ have an option to create formatting on your own premisses. However, don't waste your time, you can't change those messages in the inspection/inspset files.
