[Vi...] Posted November 25, 2022 Share Posted November 25, 2022 Good Morning. I've got some issues doing the BestFit of one of three samples. In the first image you can see a correct BestFit of one piece, and in the other image you can see that the same piece but other sample doesn't do BestFIt correctly. I tried to do Local BestFit but i'm unable to achieve it. Anyone knows how to rotate the mesh? Or do a proper BestFit? Thanks. Link to comment Share on other sites More sharing options...
[Vo...] Posted November 25, 2022 Share Posted November 25, 2022 Hallo Victor, während der Erstellung der Bestfit - Ausrichtung hast du die Möglichkeit, einen zusätzlichen Hilfspunkt anzugeben. Diesen wählst du als Soll-Punkt auf den Soll-Daten und an gleicher Stelle als Ist-Punkt auf den Ist-Daten. Dies hilft dem Programm beim Finden einer Bestfit - Ausrichtung. Link to comment Share on other sites More sharing options...
[Be...] Posted December 1, 2022 Share Posted December 1, 2022 Additional hint: If the part has a complete rotational symmetry then you can "increase" search time to high. This often finds also the "expected" solution. But if there is only a small feature which makes the rotation unique the proposed way for an additional help point is strongly recommended. If both improvements do not lead to the "correct" result use a different initial alignment method, e.g. 'Alignment by 3 points' and create an additional 'Local Bestfit by nominal element' based on the initial alignment. Hope this helps?! Regards, Bernd Link to comment Share on other sites More sharing options...
[Ma...] Posted December 1, 2022 Share Posted December 1, 2022 In this case I use to work in this way: - construct nominal point on the CAD in the position showed in the image; - preallignment with normal time and without additional help point; - measure the actual point on the mesh using the touch point on selection (edge); - link the nominal point with the actual point using the "link to actual element" measuring principle; - construct the necessary element for doing a geometric element alignment (for example cylinder and a plane) - make the geometric element alignment using also the point I measured with the touch point for put the mesh in the correct direction. - Make a local best fit selecting all the mesh (something like a second preallignment, since now you have the mesh in the correct direction) I hope I explained myself. NB: the red rectangles are the selection for make the tocuh point on selection (edge) Link to comment Share on other sites More sharing options...
[Vi...] Posted December 1, 2022 Author Share Posted December 1, 2022 Wow, thanks for your support. I'll try all of the options you show me. 🤩 Link to comment Share on other sites More sharing options...
[Ma...] Posted December 1, 2022 Share Posted December 1, 2022 Ok, let me know I it works for you! Link to comment Share on other sites More sharing options...
[Vi...] Posted December 5, 2022 Author Share Posted December 5, 2022 Please sign in to view this quote. It works, thanks Marco.🤝 Link to comment Share on other sites More sharing options...
[Ma...] Posted December 5, 2022 Share Posted December 5, 2022 Very good! Link to comment Share on other sites More sharing options...
