PCM_Text Element
I'd like to use a formula (from a .para file) in a text element, to show the part number on the
compact printout. Calypso won't allow me to use a numeric variable, (only text). Is there a
way around this? Right now I use PCM to get the part number in the comment section of
my characteristic.
I have a similar question. I would like a alphanumeric sent to excel file. Result element won't work because it will only pass numbers, however the characteristics can be alphanumeric. Is there a workaround for this ?
I'm no expert, but is this what you need? For "POS" I use an alpha numeric.
150_59ba106a5875360ee330a6d9aa950468.txt
I don't have PCM but you got me thinking, maybe I need to look at a different excel template.
