Desktop for CMM
Can Calypso be taken off of computer and put on a new/different one? We are looking to replace the desktop. Would I need anything from Zeiss to do this? Should our IT dept be able to do this internally with some help from Zeiss tech support if needed?
If your software is 5.8 or higher you should have a dongle. It is attached to an internal USB Port under the computers cover.
It should have a tag with it that has the Machines Serial number.
If it is older then that you will need a License key that Zeiss makes for you. I don't know the email address.
I don't think they support anything older then 5.6 or 5.8
If it is 4.8 I have a guy that can make you a full License with Curve and Freeform for free.
The software version is 5.6. I have asked my area Zeiss aftermarket rep for a quote and software/licence and possibly tech support.
We are not with Zeiss care or whatever it is called. Someone else does our calibrations and service.
