[Li...] Posted April 29, 2020 Share Posted April 29, 2020 Can Calypso be taken off of computer and put on a new/different one? We are looking to replace the desktop. Would I need anything from Zeiss to do this? Should our IT dept be able to do this internally with some help from Zeiss tech support if needed? Link to comment Share on other sites More sharing options...
[Da...] Posted April 29, 2020 Share Posted April 29, 2020 Lincoln, do you have USB dongle bonded license? Link to comment Share on other sites More sharing options...
[Ch...] Posted April 29, 2020 Share Posted April 29, 2020 This should help get you going. Software Install_Rev1 (002).pdfFetching info... Link to comment Share on other sites More sharing options...
[Li...] Posted April 29, 2020 Author Share Posted April 29, 2020 I think its installed on the computer. It was probably purchased with the CMM. Link to comment Share on other sites More sharing options...
[Da...] Posted April 30, 2020 Share Posted April 30, 2020 If your software is 5.8 or higher you should have a dongle. It is attached to an internal USB Port under the computers cover. It should have a tag with it that has the Machines Serial number. If it is older then that you will need a License key that Zeiss makes for you. I don't know the email address. I don't think they support anything older then 5.6 or 5.8 If it is 4.8 I have a guy that can make you a full License with Curve and Freeform for free. Link to comment Share on other sites More sharing options...
[Li...] Posted April 30, 2020 Author Share Posted April 30, 2020 The software version is 5.6. I have asked my area Zeiss aftermarket rep for a quote and software/licence and possibly tech support. We are not with Zeiss care or whatever it is called. Someone else does our calibrations and service. Link to comment Share on other sites More sharing options...
