[Cl...] Posted April 28, 2020 Share Posted April 28, 2020 I need the operator to be prompted with two choices. One; Is the a set-up part?" Two; Is this approved for production?" Based on each question the resultant data would then be sent to one file for a set-up and a different file for production. I'm assuming it would and "If - Then" type formula? Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/ Share on other sites More sharing options...
[Er...] Posted April 28, 2020 Share Posted April 28, 2020 I don't really understand what the question is. But you wish to do something along this line? if inquireList("It this..","Production","Set-up") == "Set-up" pathForResult="c:\..." else pathForResult="d:\..." endif Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87500 Share on other sites More sharing options...
[Cl...] Posted April 28, 2020 Author Share Posted April 28, 2020 Yes. I want each prompted choice to sent the variable data to a different location/Folder. Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87502 Share on other sites More sharing options...
[Er...] Posted April 28, 2020 Share Posted April 28, 2020 Depending on what your "variable data" is, you have what you need. If you instantly wish to write to file. You can use: addToFile("path",variable) Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87504 Share on other sites More sharing options...
[Cl...] Posted April 28, 2020 Author Share Posted April 28, 2020 Mainly we use the compact printout (all characteristics) & occasionally excel. Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87506 Share on other sites More sharing options...
[Er...] Posted April 28, 2020 Share Posted April 28, 2020 Aha, then I see, so you need to change the output directory you have set in "Name for output files".. That's doable. But I suggets you copy the files to the correct location after creation. (Less confusing and more understandable how it works.) As usual there's several ways. One of many is to add this to your inspection_end_pcm.txt. if inquireList("It this..","Production","Set-up") == "Set-up" copyFile("...\results\whatever.pdf","\Setup\theresults.pdf") else copyFile("...\results\whatever.pdf","\Production\theresults.pdf") endif I've heard that that file might be executed with a delay, never used it my self so I cant tell. But try it. Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87508 Share on other sites More sharing options...
[Cl...] Posted April 28, 2020 Author Share Posted April 28, 2020 Is this what it would look like Presetting's if inquireList("It this..","Production","Set-up") == "Set-up" Post settings copyFile("...\results\whatever.pdf","\Setup\theresults.pdf") else copyFile("...\results\whatever.pdf","\Production\theresults.pdf") endif Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87510 Share on other sites More sharing options...
[Er...] Posted April 29, 2020 Share Posted April 29, 2020 No, don't use pre- or post-settings. It's a .txt-file that you place in your measument plan folder, (or the inspection folder if you wish to apply on ALL plans.) Name it "inspection_end_pcm.txt" and paste all of it there. Lean back, open a beer ans donate a dollar for kids cancer research. Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87512 Share on other sites More sharing options...
[Cl...] Posted April 29, 2020 Author Share Posted April 29, 2020 Thanks. I donate to the "Human Fund", which is ran by George Costanza. Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87514 Share on other sites More sharing options...
[Er...] Posted April 29, 2020 Share Posted April 29, 2020 I hate the Seinfeld show, guess I'm to young to understand what's supposed to be fun with it... 😃 Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87516 Share on other sites More sharing options...
[Cl...] Posted April 29, 2020 Author Share Posted April 29, 2020 The show is like Trump, in that, you either like it, or hate it. Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87518 Share on other sites More sharing options...
[Jo...] Posted April 29, 2020 Share Posted April 29, 2020 Please sign in to view this quote. Is that the charitable division of Vandelay Industries ? Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87520 Share on other sites More sharing options...
[Cl...] Posted April 29, 2020 Author Share Posted April 29, 2020 🙂 Link to comment https://qualityforum.zeiss.com/topic/15908-pcm-ifthen/#findComment-87522 Share on other sites More sharing options...
