PCM & clearance
It depends on what you wish to achive. You can make 'em variable, just right click and add formula.
But you might have something else in mind?
Thanks Eric. Pretty simple, I have a family of parts (different lengths). I would like to adjust the X+ clearance value for each P/N.
You can put a variable in the clearance cube values. This will be set at the start of the program. It is not possible to change it during a run. At least it wasn't possible a few years ago.
