Autorun pallet
In the inspection folder were making customers folders, when changing, the path changes. For one program, I can delete and reload from the new folder good to go. I think if we delete the pallet it will be gone. Is there a way to change the path on the pallet so we don't have to recreate the pallet.
Sort of sounds like you are using autorun backwards. Use autorun to organize your inspection folder by supplers. Not the other way around 🙂
Anyway, there a multiple ways, but the only time I did this, (change path on a bunch of programs) I wrote a short batchfile that replaced the drive letter c:/ to m:/ on all paths that contained "manufcorr" in the .arn-file. Thats most likely the fastest way if its more then 2-3 programs.
Autorun has a search-and-replace function for paths in the menu bar. It works, but honestly, I also prefer changing the *.arn directly when I have to do a lot of them at once. Gives me more control and flexibility.
