[Ro...] Posted April 17, 2020 Share Posted April 17, 2020 I have a fixture that holds 32 parts, 2 rows of 16. The second row is offset from the first by 25mm in X, and 25mm in Y. I'm finding that 1D linear pattern lets me do one row, 2d Linear pattern only allows for a second row that is only offset in one axis. How can this be done in the pattern menu? Link to comment https://qualityforum.zeiss.com/topic/15996-pattern-with-an-offset-in-two-axis/ Share on other sites More sharing options...
[e0...] Posted April 17, 2020 Share Posted April 17, 2020 Why not use the palletizing function directly in AutoRun? You just have to define the offsets of your fixture and it will create the array itself. Link to comment https://qualityforum.zeiss.com/topic/15996-pattern-with-an-offset-in-two-axis/#findComment-88314 Share on other sites More sharing options...
[Ma...] Posted April 17, 2020 Share Posted April 17, 2020 Ronan, can you measure this in the Auto-Run Surface? There you can select a pallet measurement. Stay well. Link to comment https://qualityforum.zeiss.com/topic/15996-pattern-with-an-offset-in-two-axis/#findComment-88316 Share on other sites More sharing options...
[To...] Posted April 17, 2020 Share Posted April 17, 2020 Please sign in to view this quote. Keep 1d linear pattern for one row on feature. Copy and paste the feature. Edit X and Y nominal to reflect 2nd row position. 1d linear pattern will work from copied feature. If 2nd row has different number if features, a new 1d linear pattern will need to be created. Link to comment https://qualityforum.zeiss.com/topic/15996-pattern-with-an-offset-in-two-axis/#findComment-88318 Share on other sites More sharing options...
