3D camera hardware for GOM correlation
I would like to ask if it is necessary to use Aramis 3d Camera with GOM Correlate can I replace it with another  camera type?  if yes could it be mentioned thanks for your help in advance
Hi Omar,
in the SW Correlate you can only inspect measurement series. You can chose different ways to create this measurement series.
For a 2D measurement you can use mostly any pictures. It's recommended to be a 8-Bit image. This images can created in nearly each way you like to.
For a 3D measurement you need a calibrated system. You must have the image series of both cameras and the compatible calibrate file from your measuring volume. Therefor, it's necessary to use a GOM System with ARAMIS or the exception Photron cameras (highspeed) but also with a calibrated volume. Of course we offer two different types of stereo camera systems. One with a fix frame (3D Camera) and one with an adjustable slider for each camera (adjustable Base).
I hope this helps.
Greetings, Ivan
