ISO 2768 Tolerance
I'm trying to figure out what you are asking.
You want your tolerance to be set in calypso? what is the chart you are trying to work from?
PCM with (if <= then and >= then) statements would do that for you. Set the limits and the applied tolerances per your requirements.
Am I missing something? Calypso already has all of those tolerances built in. You just need to select the class, fine, medium, etc., then based on the nominal value, the correct tolerance automatically pops up.
HA. However, I think I may have found something Zeiss might be able to add in a future release. The ability to choose the class from within the Characteristics Editor. Unless, I missed it.
Sorry All,
I didn't realize that the first one on the list titled general tolerances was ISO 2768. My bad. For future reference where does it say that this one (general tolerances) is ISO 2768? Thanks for the help.
Kyle
It goes without saying,ISO is the grandfather of all the standards.... Unless otherwise specified it should be ISO....
